Activity Forums Apple Final Cut Pro Legacy Keeping viewer the active window.
  • Keeping viewer the active window.
    Posted by Scott Davis on May 12, 2005 at 11:03 pm
    I have some large clips I am quickly going through, setting in/outs and insert editing them into the timeline. After each insert I have to reactivate the viewer. Is there a way to keep the viewer the active window during a process like this?
    Scott Davis
    Sean Lander replied 21 years, 3 months ago 4 Members · 5 Replies
  • Kevin Monahan
    May 12, 2005 at 11:10 pm
    No, just tap the Q key.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Videomansf
    May 12, 2005 at 11:21 pm
    Also i would recommend a colored FCP keyboard. I have used FCP since version 1.0, and at version 3 got a keyboard. I learned more about fcp from the keyboard that I did from years of mousing around. Oh, and the sticky things apple ships come off and are very tacky.
    Adam
  • Kevin Monahan
    May 12, 2005 at 11:28 pm
    Loren Miller’s Key Guide is more thorough than a keyboard. It carries all the option, cmd and cntrl key combos as well.
    https://lormiller.home.mindspring.com/
    Kevin Monahan
    fcpworld.com
  • Scott Davis
    May 13, 2005 at 2:39 am
    Thanks guys.
    Scott Davis
  • Sean Lander
    May 13, 2005 at 12:54 pm
    A few people including myself have asked for this. Hopefully Apple will listen. I’ve mapped Shift-SpaceBar to toggle source/record. That way you can easily keep you fingers over the all important J K L.
