Activity Forums DSLR Video keeping Timecode on conversion of clips?
  • keeping Timecode on conversion of clips?
    Posted by Michael Williams on November 16, 2012 at 6:07 pm
    I regularly use MPEG Streamclip to convert DSLR footage to ProRes 422 before editing in FCP. However, for one of my clients this has been problematic because they reference the timecode numbers from the original clips. Each new converted clip begins at ZERO so the original timecode numbers become pointless.
    So, does anybody know a way to convert these clips while keeping the timecode numbers?
    Mike
    Michael V. Williams
    producer/editor
    http://www.vernonvision.com
    Michael Williams replied 13 years, 10 months ago 2 Members · 2 Replies
  • Bouke Vahl
    November 18, 2012 at 11:49 am
    Mike,
    QTchange can do this.
    Load the clips (set your FPS first!), then save attributes.
    Next to your clips a small file called ‘filename.att’ wil be saved.
    Then place these att files next to your rendered files (the renders should have the same filename, or a longer filename, the beginning must match)
    In QTchange, select the ‘use tc from attributs’, then load the renders.
    Highlight ‘refresh timecode’, and press ‘do it’.
    Should do the trick.
    Get QTchange here: (there is a free demo)
    https://www.videotoolshed.com/product/42/qtchange
    hth,
    Bouke
    smart tools for video pros
  • Michael Williams
    November 18, 2012 at 7:44 pm
    This looks promising. Thanks!
