Activity Forums Adobe After Effects Keeping the same distance objects
  • Keeping the same distance objects
    Posted by sara de avila on May 10, 2021 at 7:43 pm
    Hello guys! I’m new iusing after effects and i realliy need help. Does anyone know how can i have 1 controller that allows me to edit the distance between 10 objetcs at the same time, keeping always the same distance between them and without change de size?
    Thanks so much if you are reading these
    sara de avila replied 5 years, 4 months ago 2 Members · 10 Replies
  • 10 Replies
  • Chris Voelz
    May 10, 2021 at 10:27 pm
    You can use a slider on a null to control the distance.
    Then use index of a layer + slider to link everything together. This is all via expressions on the position of each layer.
  • sara de avila
    May 10, 2021 at 11:03 pm
    Thank you so much for answer! <3
    I never used slider and i only know how tu use very simple expression like “loop” or “wiggle”. You think that for these case i can learn how to do it (and i would really apreciate if you know some video or tutorial where i can learn) or is it too advanced and no way i can learn that in one or two days?
  • Chris Voelz
    May 11, 2021 at 1:18 am
    You can for sure learn it and it would actually be a good exercise that will help you further understand expressions. I can post an example tomorrow.
  • sara de avila
    May 11, 2021 at 10:52 am
    Wow thank you sooo much <3 I would really, really apreciate learning that
  • Chris Voelz
    May 11, 2021 at 6:29 pm
    You can duplicate the layers to see how it works when you add more objects. Use the slider on the null to control the distance between each layer. The index value inside of “layer(index+1)” is looking at the layer below it. So if you change the stacking order it will alter how the position is calculated. I left some notes inside the expression to help you understand what is going on. As you will quickly figure out there is more than one to do something in AE, this is just one approach.
  • sara de avila
    May 11, 2021 at 6:40 pm
    Thank you! I just think i’m doing something wrong, but nothing is happening when i move the slide or the position of the objects
  • Chris Voelz
    May 11, 2021 at 7:03 pm
    Are you changing the value in the Effect Controls?
  • sara de avila
    May 11, 2021 at 7:31 pm
    Yes. It would be just move the value of the slide control? or are there other things i shoud change?
  • Chris Voelz
    May 11, 2021 at 7:51 pm
    Ahh! You will probably need to change the expressions to match the Spanish equivalents. I’m not sure if that is automatic or not, check the name on the “gap” variable. Does effect name match the name you have? Twirl down the Layer to reveal all the expressions on Position.
  • sara de avila
    May 12, 2021 at 12:27 am
    yeeah! It was that! It’s actually portuguese hahaha but is very very simillar to spanish. I changed to english and now it is working perfectly.
    It’s really amazing how it works, thank you so much! Now i’m reading the notes and tryng to replicate to learn better how it works.
    Once again, thank you for all the support! <3
