Activity › Forums › Apple Final Cut Pro Legacy › keeping picture quality
Posted by Brett Juchniewicz on July 9, 2008 at 4:45 pmIs there a way to keep picture quality when you zoom in a clip in the viewer?
David Roth weiss replied 18 years, 1 month ago 2 Members · 3 Replies -
David Roth weiss
July 9, 2008 at 4:57 pmBrett,
The scaler in FCP is pretty decent and does a very reasonable job of anti-alaising, or smoothing, the pixelation that often happens when zooming in on video over at 100 percent. For instance, I’ve gotten very good results when scaling up to 133% when using 4×3 SD video in a 16×9 SD project. However, there are limits to everything. Just how much are you zooming in?
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Brett Juchniewicz
July 9, 2008 at 5:00 pmThe highest one of my clips is scaled to is 120. The quality is good but if you look closely enough you can see the slightest blur in the video, especially when an object is moving.
David Roth weiss
July 9, 2008 at 6:05 pmWhat you’re seeing is in fact the anti-aliasing at work, which smooths the image slightly and hides the blockiness that would otherwise be a much worse alternative. The bottom line is, when scaling-up to over 100% you’ve got to give away something. By the time your project get to it’s final destination, whether that’s broadcast, the Web, DVD, etc., no one will see that softness as whatever compression your project will encounter will degrade the video even more and make that softness less than apparent to the eye.
David Roth Weiss
Director/Editor
