Activity Forums VEGAS Pro Keeping options open between Vegas and FCPX
  • Keeping options open between Vegas and FCPX
    Posted by John Kirkilis on December 28, 2011 at 6:36 pm
    Now that the Christmas holiday is behind me, I can answer some of the follow-up questions that were offered after an earlier post.
    My wife and I are working on our first documentary. I have a new MacBook Pro quad-core i7 with a 12TB Promise Pegasus Thunderbolt RAID drive. My wife will be doing the logging and rough cut for a trailer, so I wanted to use a platform that would be the best for her while keeping my options open to select the appropriate NLE at a later date. All of my NLE experience is with SD footage on Vegas 6 several years ago. At home, I own version 11 of Vegas Media Studio Platinum. I’ve held off on spending the $500 or so for the upgrade to Pro given the gnashing of teeth I’ve heard about in this forum and Sony’s with the latest builds.
    I also own FCPX/Motion/Compressor. The forums of both products, FCPX and VP11, are full of nightmare stories indicating that they are both not ready for primetime, although they reportedly work fine for a fortunate few. I want to keep my options open as long as possible with these two products, hoping that Apple and/or Sony will get their respective acts together sooner or later. This could be a dangerous assumption, so I’m not against checking out another option if it comes to that.
    I archived my AVCHD 1080/24p footage on an external HD each day of shooting. Over the Christmas holidays, I figured I’d test the new Pegasus array by asking FCPX to ingest and transcode the footage to ProRes 422 HQ as ProRes Proxy. I also had FCPX analyze the footage for video and audio problems to provide some read testing. (There were early reports from first adopters that some of the disks in the Promise arrays being DOA, so I figured that this would be somewhat of a burn-in test.) All is fine with mine to date.
    I’ve experimented and discovered that Vegas Movie Studio can work with both the Original Media mov file (H.264) generated by the FCPX ingest process as well as the ProRes 422 transcoded media. I’ve heard that VP11 can ingest and edit the AVCHD directly, although I haven’t tested it myself. The FCPX ingest of the AVCHD directories leveraged whatever metadata that was included in that directory structure to suture the files that the camera (Sony HDR-AX2000) split into 2GB segments. Every Vegas transition and FX I’ve thrown at the ProRes media thus far hasn’t caused a hiccup in the Preview window except for some of the 3D flips, and quick pre-renders took care of those. This was all running through the Parallels virtualization layer. I half expected it to crawl or crash. Vegas can play nice with the content I’ve already transcoded through FCPX, even though this wouldn’t represent a normal workflow. I’m assuming that if VMS can do it, then so can VP. I also opened the VMS project in the trial version of VP11 to verify that the upgrade path worked correctly.
    So there’s my background on this project.
    The Apple ProRes codec on Windows is supposedly read-only, so if I used Vegas to manual split, render, and name my physical “sub-clips”, I couldn’t use ProRes 422 to render the sub-clips and would need to render to another format. VMS offered Sony XDCAM as a possible candidate. If I stayed with this back assward workflow [highly unlikely] (AVCHD -> ProRes 422 -> XDCAM), would I suffer much degradation in fidelity? It seems like it would be a lot more streamlined to edit the original AVCHD archives if I used Vegas, although I’d want to run the mts files through Sony’s Content Management Utility to sew those 2GB segments back together. When I try to do this manually in the Vegas timeline, I lose a frame according to the timecode and there is an audible dropout.
    I should also mention that we’re going to do a second shoot in March.
    Enough rambling.
    Since I’ve already paid the transcode toll, is there any benefit to staying with the ProRes media rather than work with AVCHD in Vegas?
    John
    Mike Kujbida replied 14 years, 8 months ago 2 Members · 11 Replies
  • 11 Replies
  • Mike Kujbida
    December 28, 2011 at 10:00 pm
    My suggestion is to install the Avid Codec 2.3.7 on both the Mac and PC and transcode your AVCHD footage to Avid DNxHD which both NLEs will understand, read and render.
    As always, a short test is strongly recommended.
  • John Kirkilis
    December 28, 2011 at 10:34 pm
    Thanks. I tried to install the 2.3.2 version yesterday and it failed. I’ll try 2.3.7.
    So, if I transcode to DNxHD, split the media manually in the Vegas timeline, and render these “sub-clips” individually into their own files in DNxHD, will Vegas’ smart-render kick in and not try to recompress the media?
    I’d answer my own question now, but I’m away from my computer.
    John
  • Mike Kujbida
    December 28, 2011 at 10:46 pm
    Since you’re rendering to another format, Vegas will not smart render 🙁
    Once you’re in that format though, all subsequent renders to the identical settings should be very quick.
  • John Kirkilis
    December 28, 2011 at 11:18 pm
    Supposedly, FCPX takes the original AVCHD footage and rewraps it with a Quicktime container, leaving the H.264 intact. Since FCPX cleanly rejoined the 2GB segments produced by the camera, is there any reason I shouldn’t use these mov files? Recall that Vegas will not correctly join the 2GB mts file segments when I place them contiguously in the timeline. Vegas does not seem to care about the meta data in the AVCHD directories archived from the memory cards, since it doesn’t enable the “OK” button until I’ve selected an mts file in the Streams directory.
  • John Kirkilis
    December 29, 2011 at 5:06 am
    Here’s some info on a sample mts file from my camera:
    From Videospec:
    *** General Parameters ***
    – Name: 00006.MTS
    – Container: Mpeg Transport Stream
    – Size: 1.084 GB
    – Duration: 6mn 29s
    – Bitrate: 22.2 Mbps
    *** Video Track Parameters ***
    – Format: H.264/MPEG-4 AVC
    – Bitrate: Max.: 22.0 Mbps / Average: 21.1 Mbps / Min.: Undefined
    – Frame rate (fps): Max.: Undefined / Average: 23.976 / Min.: Undefined
    – Encoding profile: High@L4.0
    – Image size: 1920*1080
    – Pixel Aspect Ratio: Undefined
    – Display Aspect Ratio: 16:9
    – Interlacing: Progressive
    *** First Audio Track Parameters ***
    – Format: AC3-A52
    – Bitrate: 256 Kbps
    – Resolution: 16 bits
    – Rate: 48.0 KHz
    – Channel(s): 2 (stereo)
    – Position: Front: L R
    From Media Info:
    General
    Complete name : /Volumes/Lili Primary/AVCHD AX2000 Raw/Lili Interview 3 and Mary/AVCHD/BDMV/STREAM/00006.MTS
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 1.01 GiB
    Duration : 6mn 29s
    Overall bit rate mode : Variable
    Overall bit rate : 22.2 Mbps
    Maximum Overall bit rate : 24.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : 27
    Duration : 6mn 29s
    Bit rate mode : Variable
    Bit rate : 21.1 Mbps
    Maximum bit rate : 22.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.423
    Stream size : 978 MiB (95%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Codec ID : 129
    Duration : 6mn 29s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 11.9 MiB (1%)
    When I go to create a custom Quicktime template in Vegas for the DNxHD codec, I’m given several attributes that I’m not quite sure how they should be set for this joint use of footage between FCPX and Vegas such as:
    Color Levels: 709 or RGB Levels
    Alpha: None, Compressed, Uncompressed
    Resolutions: (there are many choices. I can decipher the 720 vs. 1080, progressive vs. interlaced, framerate, and bit-depth, but there’s another number without any prefix or suffix, which might be the bitrate, but I’m not sure.
    I’ve attempted to attach a screenshot to this post:
  • Mike Kujbida
    December 29, 2011 at 10:40 am
    “Supposedly, FCPX takes the original AVCHD footage and rewraps it with a Quicktime container, leaving the H.264 intact. Since FCPX cleanly rejoined the 2GB segments produced by the camera, is there any reason I shouldn’t use these mov files?”
    Vegas can’t render out true H.264 files so if all you want to do is import them, go right ahead.
    “Recall that Vegas will not correctly join the 2GB mts file segments when I place them contiguously in the timeline”
    Have you tried using the software (Sony PMB?) that came with the camera to do this?
  • Mike Kujbida
    December 29, 2011 at 7:44 pm
    “When I go to create a custom Quicktime template in Vegas for the DNxHD codec, I’m given several attributes that I’m not quite sure how they should be set for this joint use of footage between FCPX and Vegas such as:
    Resolutions: (there are many choices. I can decipher the 720 vs. 1080, progressive vs. interlaced, framerate, and bit-depth, but there’s another number without any prefix or suffix, which might be the bitrate, but I’m not sure.”
    Based on the response below that I found on another Vegas forum (I don’t use DNxHD so I had to go searching for answers), it looks like the answers to your questions are:
    709color level;
    Alpha – compressed;
    8 bits at 145Mbps.
    DNxHD is visually lossless, can deliver compressed or uncompressed Alpha, and proper REC 709 luminance is faithfully preserved in the round trip to Mac and back.
    It compares favorably to ProRes 422 in all areas and has the advantage of being truly cross-platform.
    Plus, DNxHD 8 bits at 145Mbps is about 1/8th the size of uncompressed, iirc.
    10 bit, 220Mbps is also an option.
  • John Kirkilis
    December 29, 2011 at 7:55 pm
    I don’t know about PMU, but for my camera, they refer to CMU, Content Management Utility, which I’ve downloaded and run before to handle the case when a clip spans memory card A and B in the camera. You’re absolutely right, I should run all of my archived AVCHD directories through that utility first before doing the transcode to DNxHD. If I run everything through Compressor to get to DNxHD, I wonder if Vegas will employ Smart Rendering logic for the raw footage splitting. I’m not sure I’ll be able to tell if Smart Rendering is being applied though.
    I’ll experiment when I get home, but if you have any thoughts to offer, I’m all ears. Thanks for helping me negotiate this terrain.
  • Mike Kujbida
    December 29, 2011 at 8:24 pm
    “I don’t know about PMU, but for my camera, they refer to CMU, Content Management Utility,…”
    Same thing, different manufacturer, different utility name.
    “I’m not sure I’ll be able to tell if Smart Rendering is being applied though.”
    If you’re rendering to the exact same settings, your Preview window (Pro 10 screenshot) will look like this.
  • John Kirkilis
    December 30, 2011 at 7:59 pm
    I’ve got few bugs to flush out before I give these settings a try… literally. I came home to discover a bunch of tiny ants crawling on my laptop. Some seemed to be coming out of one of the air vents of my MBP. I’ve seen ants destroy less expensive electronic devices. I powered everything down and moved my gear to a white surface where it would be easier to see the little buggers. I should probably open the laptop and take a peek inside just in case.
    I’m reading up on some DNxHD white papers on Avid’s site at the moment. If my setup can handle the bandwidth, is there a benefit to going with the 10-bit 220x option if we’re only dealing with a rough cut for the foreseeable future?
    Also, have Vegas’ export capabilities improved in the last few versions that would allow us to hand off a rough cut to a real pro for color grading, etc. using their own tools?
    John
