Activity Forums Avid Media Composer keeping keyframe durations when changing the effect length
  • keeping keyframe durations when changing the effect length
    Posted by Jack Neiswanger on April 25, 2007 at 1:03 am
    Does anyone know how to keep an effect’s original keyframe duration after you extend the effect to make it longer. For example if my inital effect is 2 sec’s long with keyframe durations of 10 frames. How can I keep my keyframes at 10 frames when I extend my effect to 4 seconds without going in to the effect and physically moving the keyframes. Thanks.
    gilrun
    Jhones replied 19 years, 4 months ago 3 Members · 3 Replies
  • Grinner Hester
    April 25, 2007 at 2:15 am
    you can’t. You’ll have to drag your keyframes accordingly.
    Just hold down alt and drag em where ya want em.
    Alternativly, if it’ll work with the clip, you can hop back one fram on that clip, add an edit then trim that last fram out. This will hold all those keyframes in place before that new cut. You may wanna then hop into that new stretched out clip and remove the effect or delete the kayframes after the first one.
    that make any sense?
  • Jack Neiswanger
    April 25, 2007 at 2:25 am
    thanks for the suggestion. I will try that.
    gilrun
  • Jhones
    May 5, 2007 at 5:53 pm
    acctualy u can. u need to promote the fx editor to advanced and then u can right click the key and mark it “Fixed”.
