Activity Forums Avid Media Composer Keeping date info on consolidation
  • Keeping date info on consolidation
    Posted by Paul Allen on March 25, 2011 at 12:29 pm
    Hi all,
    I take footage from my Panasonic HPX171 and then transfer it to a hard drive – I then link to this hard drive via AMA on my Avid and consolidate the footage onto my internal drives. It works really well, but the only downside is that I lose the creation date information as this is replaced by the date I do the consolidation. Is there any way of keeping this shooting date information on the consolidated clips? It just helps to keep the clips in order.
    Paul
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme CPU QX6800 2.93GHz (4 CPUSs). 2030MB RAM. 256MB Nvidia Quadro/FX1500 PCIe
    Paul Allen replied 15 years, 5 months ago 4 Members · 5 Replies
  • Bouke Vahl
    March 25, 2011 at 5:35 pm
    Copy the info in the bin to another (custom) field prior to consolidating?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Hector Berrebi
    March 26, 2011 at 6:18 pm
    paul,
    just as a side note, P2 material is MXF and supported native on MC via AMA
    you don’t have to consolidate to be able to edit and even FX and grade
    just copy the camera folders to a dedicated location on your internal drive (or a fast external drive) and link.
    you might need to transcode or consolidate your sequence at the end… but that is a lot simpler
    hector
    Hector Berrebi
    prePost Consulting
  • Paul Allen
    March 27, 2011 at 6:05 am
    Thanks Bouke – very useful idea. Will give that a try.
    Hector – yes, I can definitely see the benefit of that work flow. I normally go for the consolidate option as I’m used to having all my media ingested and am a bit scared about the posibility of me moving something by accident! At least if everything is in the Avid Media Files folder then I know I won’t move that by mistake. I probably need to train myself in the new ways of Avid more though…
    Many thanks for your help and advice,
    Paul
  • Job Ter burg
    March 27, 2011 at 9:57 am
    Much safer would be to choose the ‘old’ P2-Import Clips / Import Media method (which shows up when you disable AMA and relaunch MC).
    That gives you a checksum copy in the right place with Avid-created containers. Just as fast as a copy.
  • Paul Allen
    March 28, 2011 at 9:01 am
    Thanks Job, I wasn’t aware of that method – I think I know the old import P2 clips options which you’re refering to.
    Thanks as always for your help,
    Paul
