Activity › Forums › VEGAS Pro › keeping audio separate after mpeg render
  • keeping audio separate after mpeg render
    Posted by Mike Kujbida on January 30, 2011 at 4:27 pm
    Asking the question below for a friend whose internet access is limited these days.
    i suggested that he send them separate WAV files but am open to any suggestions.
    i am in cairo at moment as CTV new middle east bureau chief..
    i am editing with Vegas…trying to understand how to ensure i get split track audio when i export to mpeg2 using main concept…
    i have been panning left for voice and right for natsound and interviews.. but for some reason when i feed to toronto it comes in mixed..
    when i play on my laptop…the exported file that is…it appears split…any suggestioons?
    Mike Kujbida replied 15 years, 8 months ago 2 Members · 2 Replies
  • John Rofrano
    January 30, 2011 at 5:53 pm
    What template is he using? Is he rendering in stereo? Because if he’s rendering in mono, it would combine the tracks again. If he is rendering in stereo I don’t see why the left and right channels would not be separated.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    January 30, 2011 at 6:05 pm
    John, I was doing some playing around when you sent this and I realized that you’re right and someone (probably back in Toronto) is wrong.
    Here’s my reply to him.
    I did more experimenting and, as long as you were doing a stereo encode, the two tracks are indeed still separate.
    To prove this, bring the rendered file back into Vegas, unlock the Master Output fader and slide each down individually.
    You’ll hear each track separately.
    The key is that Toronto needs to feed this signal into an audio board that allows for independent control of single stereo (i.e. L & R) channels.
    If they don’t have that capability, have them bring it up on two channels simultaneously and pan one hard left and the other one hard right just like you’re doing in Vegas.
    If they can’t figure out how to do this, tell them that my day rate is very reasonable 🙂
