Activity › Forums › Apple Final Cut Pro Legacy › keeping audio in sync when capturing fcp 5.0
  • keeping audio in sync when capturing fcp 5.0
    Posted by Mr. Fiddle on September 10, 2006 at 6:19 pm
    when i capture (dvx 24p-not advanced) some of the clips lose sync by several frames-sometimes a second or two. i believe all my settings are correct and i have been breaking up the captures into no more than 20 minute segments (if i capture an hour tape, i’ll set markers at 20 min, 40 min and 60 min, then batch capture.) is there a way to ensure perfect sync? i plan on loading a hundred or so hours and this problem is severely impeding the process. any help would be greatly appreciated. thanks
    Jeremy Garchow replied 20 years ago 2 Members · 1 Reply
  • Jeremy Garchow
    September 10, 2006 at 6:48 pm
    Look on your FCP install disk in the extras folder. There’s a folder marked DVX100 Audio sync tool. Install and sync away.
    Jeremy
