Activity Forums Apple Final Cut Pro Keeping audio in multi cam consistent
  • Keeping audio in multi cam consistent
    Posted by Brett Sherman on December 5, 2013 at 9:45 pm
    This is probably a dumb question, but I can’t figure it out. How do you keep audio consistent in a multi cam clip when switching between cameras. I want the audio from one camera to always be the audio. Whenever I switch angles it also switches the audio so I have to manually switch it back. There has to be a way to do this.
    Kevin Rease replied 12 years, 8 months ago 2 Members · 1 Reply
  • Kevin Rease
    December 5, 2013 at 10:28 pm
    In the top left corner of the multicam angle viewer, you will see 3 icons. The first, which is probably highlighted switches the audio and video when you switch angles. The second switches only the video and the 3rd does only audio…I may have the last two switched, I’m not in front of FCPX at this moment. You will and to select the angle that has the audio you want and pair that to the angle to switch video only. When you change angles, this should keep the audio you want while switching angles.
