Keeping animation speed constant when comp is nested & timestretched
So, basically I was stumped today by something which sound simple at first, but I couldn’t figure out a way to implement it: we want to use the new responsive design feature in AE to make an Essential Graphics template which animates in and out with a predefined speed (easily done with protected ranges), can be shortened or extended in a PPro timeline as required and – here comes the tricky part – has in the background a permanently rotating element which should keep rotating at the same speed no matter how long the EG clip is.
As far as I can tell by poking around, the only way to achieve something like this in principle would be to drive the rotation of the element by the actual time of a generic parent composition (in this case, the PPro timeline), so that it doesn’t slow down & speed up when entering/exiting from/to the protected ranges – but as far as I can tell, you can’t actually target this via expressions.
Or am I having a ‘derp’ moment and ignore something patently obvious?
Cheers,
Andrei
