Activity Forums Adobe After Effects Keeping a mask still!
  • Keeping a mask still!
    Posted by Ian Collister on October 30, 2007 at 6:16 pm
    This should be pretty easy, but i cant find it anywhere.
    I have an object with a mask applied to it. I want to rotate the object, but keep the mask still. This should give the appearance of the object appearing from behind the mask.
    Is there any way to ‘unlink’ the mask from the object?
    The object is an illustrator file, the mask was made with the pen tool.
    Thanks for any help, still very new to after effects.
    cheers.
    Andy Hall replied 11 years ago 7 Members · 8 Replies
  • 8 Replies
  • Kevin Camp
    October 30, 2007 at 6:27 pm
    you can’t unlink a mask from a layer… you could animate the mask to act counter to the animation of the layer, but that’s usually not the easiest way….
    i would copy the mask, and paste it onto a new solid. position the solid directly above the ai layer that is masked. select ‘alpha matte inverted’ from the track matte pulldown for the ai file (this is an option in the modes panel in the timeline). now you can remove the mask from the ai layer, and the ‘mask’ will be separate from the layer’s animation.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Todd Kopriva
    October 31, 2007 at 3:11 am
    I’d precompose the layer, add the rotation animation to the layer inside the precomposition, but add the mask to the precomposition layer. If you’ve already created the mask, just cut it from the layer inside the precomposition and paste it onto the precomposition layer.
    Does that make sense?
    For information on precomposing, see the “Nesting, precomposing, and pre-rendering” section of After Effects Help.
    CreativeCOW also has many articles related to the subject by clicking on the following link…
    https://library.creativecow.net/search.php?q=precompos
    Todd Kopriva, technical editor, Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    How about taking a survey about After Effects documentation? Please?
  • Roland R. kahlenberg
    October 31, 2007 at 4:11 am
    Masks are rendered before Transforms and Transforms are rendered after Effects. Your AE render pipeline looks like this Mask>Effects>Transform.
    This is why your mask is being rotated along with the layer. If you have Collapse Transformations switched on, the render pipeline changes to Transforms>Mask.Effects.
    I’d suggest that you switch on Collapse Transformations. It should work but hopefully the change in the render order doesn’t disaffect anything else that you may have applied or changed to the layer.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Kevin Camp
    October 31, 2007 at 2:34 pm
    good tip, thanks roland…
    Kevin Camp
  • Ian Collister
    October 31, 2007 at 4:06 pm
    Cheers all!
    I went for Moldys first reply. It worked a treat. Thanks again.
    c
  • Jon Merrifield
    November 17, 2014 at 1:01 am
    For anyone else looking for this.
    You can hold down the Y key (the pan behind tool)to re-position the fill inside your mask. For rotation however, I just use an alpha track matte on a mask only layer…
    Jon Merrifield
    PELi VFX
  • John Lucas
    July 16, 2015 at 1:57 pm
    Hey, Jon! Very nice tip! I was googling around for tips about masks, just got into this post, and your reply was really helpful!
  • Andy Hall
    September 2, 2015 at 6:02 pm
    I am having trouble with the fill inside mine – I preposition the fill using ‘Y’ – but it affects it in another part of the mask. OR the mask has to zoom to accommodate an image coming toward the camera, and there isn’t enough composition stage behind the mask to work. See image:
