Activity Forums Adobe After Effects keeping a mask in place
  • keeping a mask in place
    Posted by Simon Robbrecht on August 16, 2008 at 9:12 am
    Is there a way to keep a mask in place (preferably without animating its path) on a layer which position is animated?
    Imagine a 3D text layer which flies in from the center of the screen. There is a section in the middle which should be masked out. The mask should stay in the center of the screen; the text comes from behind the mask and flies off screen.
    Using a range selector for the opacity is not an option because i need to do the same thing with other objects too.
    Thanks for your help.
    Simon Bonner replied 18 years, 1 month ago 3 Members · 2 Replies
  • Jordan Montreuil
    August 16, 2008 at 2:50 pm
    You could apply the mask to a solid and use the solid as a track matte for the text. Then parent the solid to the text.
  • Simon Bonner
    August 17, 2008 at 11:36 am
    Or you could precomp the text and apply the mask to the precomp.
    Simon Bonner
    youtube.com/simonsaysFX
