Activity Forums Adobe After Effects Expressions Keeping 2 text layers center when the lengths change
  • Keeping 2 text layers center when the lengths change
    Posted by Jay Mueller on September 25, 2015 at 1:14 am
    I am trying to keep the first and last names center on screen as they change. I have first name (1) right justified and last name (2) left justified, placed in the center and attached to a null. My goal is to find an expression that will shift the null’s “x” position to re-center the names when they change. ie: from “jimmy smith” to “ed lichtenstein”. As you can tell the latter of the two names won’t be centered.
    I found the expression below but doesn’t quite do the trick.
    var w1= thisComp.layer(1).sourceRectAtTime().width;
    var w2 = thisComp.layer(2).sourceRectAtTime().width;
    [(thisComp.width-(w1+w2))/2,value[1]]
    Please help and THANK YOU!
    Jay Mueller replied 10 years, 11 months ago 2 Members · 4 Replies
  • Dan Ebberts
    September 25, 2015 at 2:54 am
    Assuming the null is between the two layers, it would be something like this:
    [thisComp.width/2 -( w2-w1)/2,value[1]]
    Dan
  • Jay Mueller
    September 25, 2015 at 2:40 pm
    Thanks for the quick feedback, but I get similar outcomes as with the previous expression I found. Offset to the left or right, depends on which name is longer. Just curious if you are aware for a fix for this? Thanks again!
  • Dan Ebberts
    September 25, 2015 at 5:41 pm
    Hmmm…. It works for me. Your text layers aren’t scaled, are they?
    Dan
  • Jay Mueller
    September 25, 2015 at 5:46 pm
    BINGO! That was it. My text layers were scaled to 50%. THANK YOU!!!
