Activity Forums Adobe After Effects keep the text static
  • Moira Elefson
    September 8, 2009 at 7:38 pm
    Detect the problem:
    1. Change the camera angle in the preview box to top(there is a button somewhere in the bottom of the preview window). If you change the angle you’re able to see the “real” camera moving around.
    2. Zoom out or in if nessesary
    3. Play the preview
    4. You should be able to tell how to camera moves and (maybe) detect the problem
    In a camera there is 2 very important properties:
    Position
    Focus point
    (i’m not sure about the names)
    Possible problem/solution:
    It looks like the camera’s position is moving while the focus point don’t move at all, this should be opposite.
  • Efi Or
    September 8, 2009 at 8:59 pm
    ok it worked. thank you
