Activity Forums Avid Media Composer KEEP KEY FRAMES – USE DIFFERENT EFFECTS
  • KEEP KEY FRAMES – USE DIFFERENT EFFECTS
    Posted by Jason Spencer on January 9, 2008 at 9:05 pm
    On Adrenaline… using PLUG-IN effects (Saphire). If you want to experiment with different filters, how, if you have set key frames, can you throw in different effects yet keep your set key frames?
    Grinner Hester replied 18 years, 8 months ago 2 Members · 1 Reply
  • Grinner Hester
    January 10, 2008 at 3:00 am
    if you are just wanting to save some effects you have created, drag the effect icon in the effect window to a bin.
    you cant copy/paist key frames from one effect to the other. They will be for the effect they were copied from and wont apply to other effects.
