Activity › Forums › Adobe After Effects › keep distance between POI and camera pos?
  • keep distance between POI and camera pos?
    Posted by Peter B-b on November 9, 2008 at 2:33 am
    Hello my problem is quite simple, and I’m thinking of coming up with a mathematical calculation to solve it but there must be a simpler way.
    For simplicity’s sake I will be talking about my problem in 2D because it’s the same concept. My problem, basically, that I want to “lock” the distance between the camera and the POI. The trouble is that when I want the camera to behave like this (ignore dots):
    .........stop keyframe
    ..............\ <---- Camera path
    .....POI......|
    start keyframe
    Which is circular around the POI, when in reality it does this:
    .....POI/
    start keyframe
    The key difference between the two is that in the second, the distance between the POI and the camera changes. I need that to be locked.
    I tried putting multiple keyframes to "help" it, but the motion was too jaggety... unless I was doing the wrong easing...
    Anyways can anyone help me with this... I'm tired and desperate!! Thanks 🙂
    Jerry Witt replied 17 years, 10 months ago 5 Members · 5 Replies
  • Avrohom Kohn
    November 9, 2008 at 6:31 am
    why don’t you view from the ‘top’ view, and adjust the handles of the motion path (visually keeping the same distance)?
  • Jan Sherlink
    November 9, 2008 at 2:30 pm
    Create a null where your POI should be,
    make your null and POI the same coördinates,
    parent the camera to the null,
    and rotate the null to have a nice circular motion around an object.
    hope that helps
    cya,
    Jan
  • Peter B-b
    November 9, 2008 at 4:47 pm
    Thanks guys they’re both good ideas
    Avrohom: i’ll give it a shot, but i still have a feeling it will be a bit jerky.
    Jan: I think this makes the most sense for what I’m doing but the thing is I need the camera to do other things after that, and I don’t think it’s possible to “de-parent” at a certain point. I’ll look into it definately though
    Thank you!
  • Simon Bonner
    November 9, 2008 at 8:30 pm
    You can’t de-parent, but you can split your camera into two layers (ctrl+shift+d) at the point where you no longer want it to be parented. Unparent the second layer.
    Simon Bonner
    youtube.com/simonsaysfx
  • Jerry Witt
    November 10, 2008 at 6:28 am
    Yes, or you could just stop using the null and then animate the camera itself. You can also use a chain of multiple nulls. Any of these ideas is easier than trying to do it mathematically, IMHO.
