Activity Forums DaVinci Resolve keep Da Vinci from scanning audio plugins
  • keep Da Vinci from scanning audio plugins
    Posted by Pj Wassermann on December 28, 2021 at 4:38 pm
    How can you keep Da Vinci from scanning audio plugins?
    I’m a musician and I have way too many audio plugins. In order to make them work on the laptop I need to move the licenses from my studio computer and I dont want to do that every time.
    Thanks for your help!
    Pj Wassermann replied 4 years, 8 months ago 2 Members · 2 Replies
  • Michael Gissing
    December 31, 2021 at 12:29 am
    You can set in preferences the folders that Resolve scans for audio plugins. You might want to limit the plugins you use by copying a smaller group to a single folder so Resolve only looks and loads those plugins you want to enable. Once you have done that, if you have moved the license you can remove that folder in preferences and easily add it back when the license is available or in the next panel down, disable all then enable all when the license is available. This will require reboot of resolve but it will stop constant scanning
  • Pj Wassermann
    December 31, 2021 at 9:55 am
    Cool, thanks a lot!
