Activity Forums DaVinci Resolve Keep camera metadata ISO but switch to RedLogFilm when grading R3D?
  • Keep camera metadata ISO but switch to RedLogFilm when grading R3D?
    Posted by Nat Jencks on December 18, 2013 at 11:29 pm
    What is the easiest way to do this? I want to grade from R3D, but when I change my clips to reference project raw settings and change to RedLogFilm, I can only use one ISO setting for every shot in the film. I’d like to use camera metadata (especially for ISO), but use RedLogFilm as the gamma curve. Thousands of shots, so tweaking these metadata setting per shot is not ideal.
    best-
    -Nat
    Dan Moran replied 12 years, 9 months ago 5 Members · 5 Replies
  • Sascha Haber
    December 19, 2013 at 7:13 am
    Did you try changing the attributes in Red Cine ?
    A slice of color…
    Resolve 10.0.0.073 , Smoke 2013 EXT
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Nat Jencks
    December 19, 2013 at 9:26 am
    Hmm, that’s an interesting idea. Is there a way to batch change meta data for huge #s of files? Thanks Sasha.
    -N
  • Robert Ruffo
    December 19, 2013 at 4:28 pm
    No way to do that, but a good feature request over at Red if you feel like making it.
  • Chris Hall
    December 19, 2013 at 6:20 pm
    Maybe I’m misunderstanding the question so correct me if I’m wrong, but I think what you want to do is actually fairly simple:
    1) For your project settings set the Red Camera settings to “Decode Using – Camera Metadata”
    2) The select all red clips in the media pool and right click on one to select “Edit Red Codec Settings”
    3) In the red settings dialogue box change “Decode Using” to “Clip” and then change “Gamma Curve” to Redlogfilm”
    4) After doing that click the left most button on the lower right of the dialogue box to “apply changes to all selected clips”
    5) This will only change the gamma curve to redlogfilm in all selected clips and keep the camera metadata for color temp, sat, tint, etc.
    Would that do what you need? (I pretty much do this on every red project and it works like a charm)
    Chris Hall
    Colorist – Prehistoric Digital
    Santa Monica, CA
  • Dan Moran
    December 19, 2013 at 11:00 pm
    Exactly right Chris, we’ve being doing this on red projects for a long time.
    If its not working for some of you make sure you select all your red clips before changing the red settings. If you change the setting, then select all and then hit the apply changes button it doesn’t work
    Dan Moran
    Colourist
    Smoke & Mirrors: London
    http://www.danmorancolor.com/blog
