Keep audio keyframes on frame marker
Is there a way to limit the a keyframe to being placed at frames and not in between frames?
I want to use the command shift+K and option+K to move between audio keyframes and use the audio mixer to adjust level…but if the keyframe is between frames and not exactly on the frame marker, it adjusts the level of 2 audio keyframes.
How are others doing this?
