Activity Forums Compression Techniques Kbit vs kbit
  • Kbit vs kbit
    Posted by Jim Wilcox on July 19, 2011 at 9:52 pm
    Been asked to provide Constant Bitrate files at 3000 Kbit/s or better for a non broadcast playback system. I am currently confusing myself about Kbit vs kbit Vs Mbit. Can someone point me in the right direction…
    Craig Seeman replied 15 years, 2 months ago 2 Members · 5 Replies
  • Craig Seeman
    July 19, 2011 at 10:05 pm
    8 bits to a Byte is the basic math.
    You might to look at this desktop widget for Mac
    https://www.pimley.net/projects/#bitratepro
  • Jim Wilcox
    July 19, 2011 at 10:19 pm
    Craig,
    I get the basic math its the K vs k that has me questioning myself. If I am setting this up in Compressor I can set kbits/s so I am assuming if they want 3000 Kbits/s I can set up 30000 kbits/s… yes?
  • Jim Wilcox
    July 19, 2011 at 10:52 pm
    Craig,
    Just want to make sure I am on the right path. Kbit is a decimal expression (1000 bytes) and kbit is binary (1024 bytes) so if they are looking for 3000 Kbits/s I can go 3072 kbit/s… ?
    And can anyone weigh in on the non overt nature of Compressor regarding doing CBR h.264 files. Do I set up as Download to not get VBR?
  • Craig Seeman
    July 19, 2011 at 10:53 pm
    kbits and Kbits are the same.
    Kb and KB can be different though. b is bit and B is Byte
  • Craig Seeman
    July 19, 2011 at 10:58 pm
    I see where the issue is now.
    binary vs decimal.
    The program I linked to uses
    KiB for binary and KB for decimal
    I believe the assumption is binary for data rates. That’s not the case with “sizes.”
    https://en.wikipedia.org/wiki/Binary_prefix
    but look at this too.
    https://en.wikipedia.org/wiki/Data_rate_units
