Activity Forums VEGAS Pro karaoke
  • karaoke
    Posted by Luigi Perrotta on November 4, 2022 at 2:09 pm
    Hi everybody,
    I am trying to work some audio karaoke files. Some of the music is a little to fast or to slow I change the speed of the audio using Aclatique timestrech on the audio track to speedup or slow down the music.
    The problem is the words that are on the video track go out of synch. I tried with video and audio as a group or separate them the result is the same.
    How can I keep the lyrics in synch if I change the audio speed?
    I use Vegas Pro 18.
    Thank you
    Luigi Perrotta replied 3 years, 10 months ago 3 Members · 5 Replies
  • John Post
    November 4, 2022 at 3:51 pm
    Set the final tempo first😂. Haha I will look into this.
  • Luigi Perrotta
    November 4, 2022 at 4:47 pm
    Than you John,
    What I’ve been doing up to now is separate the video track from the audio, split it at many points and manually move it to more or less where it belongs.
    It’s time consuming and never perfect but gives the singer the words in front of them.
    There must be a better way!
    Thank you
  • Edward Troxel
    November 10, 2022 at 6:20 pm
    Hold down the CTRL key and resize the audio and video to the new desired length together.
  • Luigi Perrotta
    November 10, 2022 at 6:45 pm
    Thank you, I need to slow down the audio track for a slower tempo music, will this do that?
    I’ll try later thank you
  • Luigi Perrotta
    November 10, 2022 at 10:32 pm
    Thank you Edward, it worked, made the file longer to slow the tempo!
    One note I like to share, when I tried to use lastigue timestretch to use the pitch shift function at the same time, it lost the synch. However, when I used a different pitch shift effect at same time it functioned great!
    Lastique timestretch has a check box to keep the body of the instrument function. The other pitch shift effect doesn’t, I changed other settings and used the EQ to get the result.
    Thank you this will save me a lot of time and fix many files to my liking!
