Activity › Forums › Adobe After Effects › Kamehameha Ball creating Question
  • Kamehameha Ball creating Question
    Posted by Nstudios on September 20, 2007 at 6:04 am
    Hi Adobe,
    I have an little problem with editing and i hope you will help me.
    I’ts about the Kamehameha Tutorial on Youtube (https://nl.youtube.com/watch?v=x9tc48FR9Tw)
    First i have an white layer that i made on top of my video.
    This layer is created by the Elliptical mask tool.
    Then my second step is to set the beginning where i want to set the beginning point where i want to see the ball start to show up. after doing this i am setting the stopwatches from
    Mask Shape,Scale and Opacity.Then my starting point is set.
    Then my third step is to go to the beginning where the ball needs to be opacity 0,00 and scale as low as possible to make it like its coming out of nowhere.
    But then if i drag the circle into another location my starting point moves without any reason, so my starting point is moved.
    Also i don’t see the little dots that animate the way the ball has to go.
    I cannot make an annimation with the frames.
    I simply does not record the layer’s location on the frames.
    In the tutorial there are little spots and i don’t have it….
    Please can u help me out with this problem, because it’s bothering me alot 🙁
    Greetings NStudios – The Netherlands.
    Nstudios replied 19 years ago 2 Members · 4 Replies
  • Nstudios
    September 20, 2007 at 9:52 am
    Problem solved!
    Next problem, when i use the shine plugin i will get a red cross in my screen that is going with the video after rendering.
    How do i get it disapeared?
  • Nstudios
    September 20, 2007 at 9:53 am
    Problem solved!
  • Mark Landman
    September 20, 2007 at 12:40 pm
    It sounds like you’re using a demo version of the plug-in.
  • Nstudios
    September 20, 2007 at 3:22 pm
    yeah thats right…
    Can i get the full somewhere?
