Activity Forums AJA Video Systems K3-Box cable length
  • K3-Box cable length
    Posted by Mathieu Marano on January 21, 2008 at 2:37 am
    Hi, I will receive my Kona 3 next week and I want to wire my patch before it gets here. Anybony knows the length of the cable that goes between the Kona 3 and the K3-Box?
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
    Mathieu Marano replied 18 years, 8 months ago 3 Members · 5 Replies
  • John Ladle
    January 21, 2008 at 7:51 am
    2 Meter cable is standard,
    when you use the break out box on any of the models, an optional 5 meter cable is available if required.
  • Bob Zelin
    January 21, 2008 at 3:35 pm
    you should assume that the cable length is going right to your MAC computer, since the cable AJA supplies is SHORT (it’s shorter than 2 meters).
    You will run the following cables to your bay –
    HD IN 1
    HD IN 2
    HD Out1
    HD Out 2
    Analog Out Y
    Analog Out R-Y
    Analog Out B-Y
    Reference IN
    Audio Out L (with an RCA plug)
    Audio Out R (with an RCA plug)
    RS422
    more lines, if you use AES/EBU audio.
    Bob Zelin
  • Mathieu Marano
    January 21, 2008 at 9:03 pm
    I will also put the AES in the patch because I will go thru an ADA4 and a D10AD to output to and capture from BetaSP.
    Oh, and my SRW5500 is my second machine room. I have to run 70 feet of cable from the Kona to the SRW5500. Should I put a DA in the middle of the line?
    Mathieu Marano
  • Bob Zelin
    January 21, 2008 at 9:57 pm
    Mathieu writes –
    REPLY –
    NO – use Belden 1505A or Belden 1694 cable, and you will have NO PROBLEMS – you ABSOLUTELY DO NOT need to DA the signal. This will work fine. Do NOT use cheap cable. (Gepco VPM-2000 cable or Canare L-4CFB cable will work great also).
    Bob Zelin
  • Mathieu Marano
    January 22, 2008 at 7:00 pm
    Thanks Bob
    Mathieu Marano
