Activity › Forums › AJA Video Systems › K2 Breakout box with K3 Board?
Posted by David Battistella on October 24, 2007 at 2:31 pmDoes anyone know if this is possible?
David
David Battistella replied 18 years, 10 months ago 7 Members · 9 Replies -
Walter Biscardi
October 24, 2007 at 3:09 pmNo, the connections are completely different on the K3.
Walter Biscardi, Jr.
https://www.biscardicreative.comStop Staring Start Grading with Apple Color The new Color Training DVD now available!
https://store.creativecow.net/p/66/stop_staring_and_start_grading_with_apple_colorRead my blog! https://blogs.creativecow.net/WalterBiscardi
Jeremy Garchow
October 24, 2007 at 3:44 pmBut the Kona 3X board works with the Kona 3e for all future posters/cow searchers.
Bob Zelin
October 24, 2007 at 8:55 pmDavid
I’ve got bigger problems than the K2 box with the Kona 3. Like when will the Kona 3 (and Kona 2) work with Leopard. And when will the SCSI/Fibre/SATA host card drivers be written for Leopard. This is the stuff that will stop you dead in your tracks.Bob Zelin
Xiaolom
October 25, 2007 at 11:28 amHi,
I read in another thread somewhere, that the K3 had issues with the MacPro. You could only run max 2 Gb of Ram to be able to work with the K3.
Is this true and has this been adressed by aja in the meanwhile??
because we intend to purchase a K3 and run it in a Mac Pro with 4 GB Ram. -
Bob Zelin
October 25, 2007 at 1:03 pmthe only issue is running Pro Res with the Kona 3 on a MAC Pro with more than 2 Gig of RAM. If you are doing ANYTHING ELSE, (uncompressed, DVCProHD, uncompressed SD, etc.) there are no issues, and you can have as much RAM as you like.
Bob Zelin
Szumlins
October 25, 2007 at 1:16 pmIt should be noted that this problem does not occur with every 8 Core MacPro either. Mine runs just fine with more than 2Gb of RAM and ProRes with a K3.
Gary Adcock
October 25, 2007 at 1:38 pm[Xiaolom] “I read in another thread somewhere, that the K3 had issues with the MacPro. You could only run max 2 Gb of Ram to be able to work with the K3. Is this true and has this been adressed by aja in the meanwhile?? “
the 2 gig limit is an issue with 4:4:4 and 2K RGB workflows only and it is an issue in QT not in the Kona Driver.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Jeremy Garchow
October 25, 2007 at 3:39 pmI don’t use 4:4:4 RGB. But I have not had a problem with 16GB in an 8 core.
FInal Cut 6 does some really weird things, but the Kona seems fine.
Jeremy
David Battistella
October 28, 2007 at 4:19 amThanks for the responses folks.
Hey Bob,
ATTO has released their drivers for Leopard (they probably write the aplle drivers for them too).
Now I just need every one of my other 27 applications to be compatible and things will be great!
Any word on whether K2 will ever work with Leopard?
David
