Activity Forums Apple Final Cut Pro Legacy JVC.mov editing Versus ProRes422
  • JVC.mov editing Versus ProRes422
    Posted by Jimmy Stephans on January 12, 2012 at 5:13 pm
    I’m currently shooting a bit with a JVC GY-HM100U that I set to save files as .mov. The link below seems to indicate that those files are just fine going to the FCP timeline without transcoding.
    https://pro.jvc.com/prof/attributes/tech_desc.jsp?model_id=MDL101845&feature_id=02
    I’ve been reading posts and sites about those shooting with a Canon 5D MK-II, which also saves a .mov file (but likely another codec?) and in those readings I often see experts say the canon produced .mov files should be transcoded to ProRes422 before editing.
    The question I have is: If the canon’s should be transcoded, should my JVC created .mov file also be transcoded?
    Thanks in advance,
    Jimmy
    Jimmy Stephans replied 14 years, 8 months ago 2 Members · 2 Replies
  • Doug Beal
    January 12, 2012 at 5:32 pm
    The JVC when set to Quicktime makes XDCamEX files which can be edited in FCP.
    The Canon5D makes h264 Quicktimes which ought to be transcoded to ProRes first.
    you might want to set the render to ProRes in your sequence if you set it up for XDCamEX.
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Jimmy Stephans
    January 12, 2012 at 5:44 pm
    Doug,
    Thanks… I appreciate the help!
