Activity Forums Apple Final Cut Pro Legacy JVC HD – newbie questions(s)
  • JVC HD – newbie questions(s)
    Posted by Kevin on August 9, 2007 at 4:23 am
    Hi list,
    newbie HD questions(s) so please be patient. I’m just figuring this stuff out.
    I captured HD 24f 16:9 media from a JVC HD camera with NTSC 24p with sequence settings,anamorphic checked. (probably the wrong way to begin the process).
    (Can anyone confirm that I should be capturing with the HD Pro Res codec which is what I have been reading on the board.)
    I’m ultimately looking to output and encode to flash keeping 24f and ratio in tact.
    I do have the 16:9 image viewable in the NTSC sequence and have finished the edit.
    When I try to output from my 4:3 NTSC sequence I get letterbox which I don’t want.
    So. Any thoughts on what I can do from here.
    When I create a HD sequqbce and copy and past my timeline, clips just occupy the middle of the 720 canvas; when I do likewise to create a 16:9 sequence and copy and past the clips from my NTSC sequqnce the image is stretched.
    My question(s) is there anyway I can use the edit I have in a new HD 16:9 project si I cn output in that ratio and then encode.
    As this is ultimately for the web I thought I might get away with outputting with letterbox and then cropping them out but squeeze wouldn’t let me do that. Is there anyway I can use an XML export to keep my cut and apply it to an HD sequence.
    Is there a 16:9 setting available anywhere in squeeze or could I accomplish cropping in another encoding program.
    Any insight into the process would be kindly received.
    Warmest,
    Kevin
    Kevin replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
