Activity › Forums › AJA Video Systems › JVC HD monitor latency
Posted by Gordon Gurley on September 17, 2007 at 4:07 pmSorry, off topic. I just got a JVC DT V24L1D, hooked to the second SDI output of my Kona LHe. There is about 1 to 2 frames of latency between audio from Kona and picture on JVC. Output 1 of the Kona (which goes to my machine room) looks fine.
I guess I can try switching the cables, but my suspicion is that it’s the monitor. Anyone else notice this?
Bob Zelin replied 18 years, 11 months ago 6 Members · 15 Replies -
Walter Biscardi
September 17, 2007 at 4:18 pmThat monitor may require an offset like our Panasonic Pro Plasmas.
In 720p I leave the Playback Offset at 0. In 1080i, I have to change the offset to 2.
So if you have a two frame lag, change that offset.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Gordon Gurley
September 17, 2007 at 4:29 pmHmm, but that seems a little scary. If I offset to match my monitor, my audio will be out of sync when it hits my deck. I’d hate to have to switch it every time I do a layoff. Is there a way to set up different offsets for each output of the Kona?
David Roth weiss
September 17, 2007 at 4:35 pm[Gordon Gurley] “I offset to match my monitor, my audio will be out of sync when it hits my deck.”
There’s nothing really changing, just the apparent relation between video and audio to correct for the monitor latency. Its not really making a shift between the two as in actually slipping audio and video.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY
Gordon Gurley
September 17, 2007 at 4:42 pmOK wait a minute, how will the offset (i’m assuming your talking the playback offset in FCP) make my Kona monitor match my Kona audio? It has no effect.
Walter Biscardi
September 17, 2007 at 4:46 pm[Gordon Gurley] “OK wait a minute, how will the offset (i’m assuming your talking the playback offset in FCP) make my Kona monitor match my Kona audio? It has no effect.”
The offset puts a slight delay in the way the video is received by the monitor so it puts your audio and video back in sync for viewing purposes.
Record to tape is not affected at all.
Gordon Gurley
September 17, 2007 at 4:52 pmI’m missing something here. FCP Playback offset only affects the desktop sync. It doesn’t seem to do anything to Kona output (thank god). What offset delays the audio from Kona to match a slow monitor?
Please put me straight if I’m missing something here.
Walter Biscardi
September 17, 2007 at 5:00 pm[Gordon Gurley] “FCP Playback offset only affects the desktop sync. It doesn’t seem to do anything to Kona output (thank god). What offset delays the audio from Kona to match a slow monitor?”
It affects the audio sync to picture. In your case, the JVC monitor sounds like it requires 1 or 2 frames to display the image correctly, just like my Panasonic Plasma requires 2 frames to correctly display 1080i material. So by adjusting the playback offset, you put your external display in sync with audio.
David Roth weiss
September 17, 2007 at 5:11 pmGordon,
Here’s the deal…
The Frame Offset setting in the System Settings–Playback Control doesn’t really change sync between audio and video, it just changes “apparent” relationship bewteen the two when monitoring through FCP both on the FCP desktop and through the Kona card. Unfortunately, some monitors require a setting that is not perfect for for both. In that situation you must chose which is more important to you, perfect sync on your client monitor or perfect sync on your FCP desktop. Does this make sense???
David
David Roth Weiss
Director/Editor
Bob Zelin
September 17, 2007 at 10:20 pmHi Gordon –
the 24″ JVC is a great monitor. All the LCD’s and Plasma’s have delay issues like you are seeing. The people that say “I don’t have any problems” can’t see a 1-2 frame delay error. CRT’s never had propogation delay issues.bob Zelin
