Activity › Forums › Apple Final Cut Pro Legacy › jvc hd-gy 110 problems
Posted by Doin What i do on July 7, 2007 at 12:37 amHello to everybody and a bigthanks to all who try to help me reslove my issues…
My problem is with final cut pro 6… I’m unable to capture a complete clip from my JVC GY-HD110 camera…Is there a fix for this ?
George Strother replied 19 years, 1 month ago 3 Members · 2 Replies -
Tom Wolsky
July 7, 2007 at 12:49 amImpossible to tell from the information provided. Why don’t you tell us exactly that you’re doing and what’s happening on your computer.
BTW, did you try doing a forum search?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
George Strother
July 9, 2007 at 4:25 pmThis is a common problem with the JVC ProHD series of cameras.
You can find a lot of information about it if you search this forum – https://www.dvinfo.net/conf/forumdisplay.php?f=98
There is a firmware update for the JVC BR-50 deck and the HD200/250 series cameras. It has been posted that JVC will release a firmware update for the HD100/110 series cameras, but no release date has been posted.
Some users say they get better results with JVC HDV tape, some with faster drives. I use a 200 MBs RAID and an internal SATA dedicated data drive with good success using mini DV or HDV tapes. From the posts, Firewire drives appear to have the most problems.
You may be able to reduce the length of the breaks (lost footage) by logging your clips, setting FCP pre-roll and post-roll to one second, then setting “handles” of 15 frames in the Batch Capture window. This can reduce the gaps from 4-7 seconds to as little as 1 second.
The only other fix I can suggest at this time is to record with a Firestore drive in additon to or in place of tape.
George
Light Images
