Activity Forums Apple Final Cut Pro Legacy JVC HD 110U workflow question
  • JVC HD 110U workflow question
    Posted by Ben Brodbeck on February 4, 2007 at 2:42 am
    I’m having that same problem everyone else is having with capturing. It stops and makes up an error about a dropped frame.
    I see that someone suggested using DVHSCAP.app to capture the footage.
    My question is, where can I find this DVHSCAP.app ???
    Ben
    Michael Bugera replied 19 years, 7 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    February 4, 2007 at 1:21 pm
    Dropped frames are usually caused by drives not being able to keep up with the data flow… not software per se. What are you using as a scratch disk and what format of HDV have you shot? How is the drive formatted?The capture utiltiy used to be on Apple’s site, but it’s not there anymore… Still I think that you should fix the problem so you can capture in FCP… sure would make things easier, right?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Ben Brodbeck
    February 4, 2007 at 8:15 pm
    Jerry,
    Thanks for the ideas. I am running Final Cut Studio 5.1.2
    I’m using an internal 250gb Maxtor hard drive (2nd hard drive, not my boot drive) as my scratch disk.
    I’ve shot 720/24p HDV on a JVC GY-HD110u camera.
    The drive is formatted as MAC OS Extended (Journaled) with 2 partitions.
    Any suggestions as to what I could do to get past this issue?
    Ben Brodbeck
  • Michael Bugera
    February 13, 2007 at 4:20 pm
    I’ve had problems with Journaled drives. I’d start be restriping as Mac OS Extended.
    Bugsy
