Activity Forums JVC Cameras JVC GY-HM750U Record limit?
  • JVC GY-HM750U Record limit?
    Posted by Sam Comer on July 26, 2013 at 1:43 pm
    My job uses the JVC GY-HM750U. On a couple of shoots where I needed to record longer events, I have ended up getting multiple split clips instead of one continuous clip. I shot a 22 minute presentation yesterday and I got a 14 minute clip and an 8 minute clip. I understand there is a limit on DSLR of 12 minutes/4Gb, but didn’t think this was an issue with a professional, dedicated camcorder.
    Is this a “feature”? Or is something set wrong?
    Cards are formatted in the camera.
    Randy Burleson replied 12 years, 6 months ago 3 Members · 4 Replies
  • Mike Squires
    August 7, 2013 at 6:31 pm
    That is normal, even in continuous mode, it’ll split clips at 4GB. This is due to the camera using FAT32 as the format type for SD cards. So technically, it’s a limitation of FAT32.
  • Randy Burleson
    August 26, 2013 at 10:03 pm
    I have experienced the same thing, but didn’t know it was a limitation of the card.
    I thought the separate clips should go together seamlessly but my editor informed me that there is a 12-15 frames of gap and that the 2 clips are not seamless in the recording or ingest.
    Could there be something wrong with the camera or the ingest process? We are ingesting from a card reader directly into FCP X.
  • Mike Squires
    August 27, 2013 at 5:34 pm
    I use PPro CC (and CS6) and my clips are seamless when put on the timeline.
    If all else fails, I guess you could use the software that came with the camera, I believe it’ll merge the clips into one large clip.
  • Randy Burleson
    February 11, 2014 at 9:45 pm
    It’s really more of a pain when you have 3 cameras that you are trying to do a Multi-cam edit on.
