Activity › Forums › JVC Cameras › JVC GY-HM100U Telephoto Converter
  • JVC GY-HM100U Telephoto Converter
    Posted by Jay Mitchell on September 14, 2010 at 7:18 pm
    What are the current options for adding a telephoto converter lens to the GY-HM100U? I see that Century Optics used to sell a 1.6x 46mm converter that is now out of production. I would like to buy a 2.x if available. I saw some posts where step-up filter rings were being tested with 58mm telephoto converters.
    Jay Mitchell
    http://www.FootageWorks.com
    http://www.ActionStockPhoto.com
    Will Granzier replied 16 years ago 2 Members · 1 Reply
  • Will Granzier
    September 26, 2010 at 4:40 am
    Hi Jay
    If I may ask what do you want to shoot – I have HDY 101’s and have the fujinon adaptor rings that I purchased. It allows you to go from a 1/3 inch (standard lens )to a half inch lens.
    I then got myself 2 old Fujinon Pegasus 2 lenses with doublers on.
    The good thing is that using the fujinon lens converter – it gives you a x 1.8 just by fitting the doubler. So your std 14 x goes to about a 25 optical… Then add the doubler on the lens and you go to a 50 x
    I shoot lots of sport action and wildlife and it works for me.
    The Pegasus 2 lenses are fairly cheap. They came std with the Sony BETASP cams pre 1999. Rocksolid, Cheap and easy to get yr hands on
    Try and stay away from converters that screw onto the front of your lens. Filters are great but converters tend to distort the images especially on the edges. Shooting in 16:9 its no good
    Hope it helps
    William
    Regards
    William
