Activity Forums Apple Final Cut Pro Legacy JVC Gy Hm 700
  • Posted by Ankur Bishaya on July 21, 2009 at 9:20 am
    Hi !
    I’m planning to purchase a GY HM700. In my studio I have G5 2.0 Ghz, 2gb ram, NVIDIA 5200 with Final Cut Studio 2. I want to know if I shoot HD at 35mbps, can I edit the footage on the same machine I have.
    If not what are the hardware I have to change without changing the G5.
    Regards,
    Ankur
    Ankur Bishaya replied 17 years, 2 months ago 3 Members · 3 Replies
  • John Fishback
    July 21, 2009 at 3:06 pm
    I’ve never used this camera, but the literature says it records .movs that can be dropped into FCP. You didn’t mention what drives you have. That is where you’ll need some speed – at least a 2-drive RAID. The acid test would be to find some footage from the camera, import it to your system, and see how it goes.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Will Granzier
    July 22, 2009 at 3:55 am
    Hi Ankur
    I have the little siter cam the HDM100 and the same system. Just uploaded FCP 6 on it and it works fine @ 35mbs.
    There are a few tweaks u have to do to make it run smoother –
    u will need to add more ram at least 2gig.
    Get a decent external HD. I use Gdrive or WD Studio pro 2. I like the WD’s as they are cheap and have a RAID 0 or 1 option. If you have the cash for more go for it.
    In FCP go to you USER settings – RENDER controls and unclick ALWAYS RENBDER AT HIGHEST QUALITY
    Hope the Helps
    Will
  • Ankur Bishaya
    July 23, 2009 at 6:52 am
    Thankyou Will
