Activity › Forums › JVC Cameras › JVC GY-HD100U Problems
Posted by Carolin Fox on October 8, 2008 at 4:09 pmsomeone can explain to me about distortion in the video
type linesman arranged the focus back but I can not find solution
I appreciate very muchEd Dooley replied 17 years, 10 months ago 2 Members · 12 Replies -
Ed Dooley
October 8, 2008 at 4:56 pmOla Carolin,
No hablo español muy bien, y entiendo muy poco, pero usted no está explicando el problema lo suficientemente bien como en Inglés. Cuéntanos más.
In English please, what distortion?
Gracias,
Ed[Carolin Fox] “someone can explain to me about distortion in the video
I appreciate very muc” -
Carolin Fox
October 9, 2008 at 10:56 pmthe word is distortions
Or type vibrations per Example when I
panning according to wed in some cities talk about this and blame the
Lens -
Carolin Fox
October 9, 2008 at 11:02 pmthe word is distortions
Lens -
Ed Dooley
October 10, 2008 at 4:08 amSorry, I still don’t understand the question. Is Spanish your language? Lo siento, pero yo aún no entiendo el problema. Pregunte en español. Tal vez pueda comprender mejor en español.
Ed -
Carolin Fox
October 10, 2008 at 3:46 pmOK una ves mas Tratare de explicarles
Por fabor Vean esta Pagina ALLi tengo un ejemplo de video
donde podran ver el problema Les Agradecere Su Respuesta
Gracias https://www.mogulus.com/esperanza2009 -
Carolin Fox
October 10, 2008 at 3:57 pmOk Tratare de explicarles una ves mas
Les Agradecere Mucho por su pronta Respuesta
Por favor viciten esta pagina ALLi Tengo un Ejemplo de viveo
y Podran Ver el problema
Ed Dooley
October 10, 2008 at 4:09 pmBasically guys, Carolin’s link explains it all:
https://www.mogulus.com/esperanza2009Up and down motion is creating jaggies (more severe than regular interlacing jaggies). Could it be a shutter speed/frame rate issue?
Carolin, what are the camera’s settings? Is it HDV or SD? Is the Frame Rate 24, 25, 30?
What is the shutter speed?
Ed -
Ed Dooley
October 10, 2008 at 4:51 pmCarolin,
Your video looks very wide, not 16×9. Have you stretched it or done something to it while editing?Su video se ve muy amplia, no 16×9. ¿Ha estirado, o hacer algo para que durante la edición?
Ed -
Carolin Fox
October 10, 2008 at 7:42 pmEn Los dos SD and HDV 30 Frame Rate
shutter speed Es 1/60 Vean el Video -
Ed Dooley
October 10, 2008 at 7:49 pmThe video is 16×9? It looks much wider. Did you stretch it while editing or compressing?
Ed
Y el vídeo es 16×9? Parece mucho más amplio. ¿Lo que se extienden cuando se edita?
