Activity › Forums › JVC Cameras › JVC GY-HD100 using HDV, and its compatibility with AVID Media composer
  • JVC GY-HD100 using HDV, and its compatibility with AVID Media composer
    Posted by Andrew Hagan on May 29, 2009 at 1:34 pm
    I have recently upgraded my Avid Express pro with Avid media composer. I am using my JVC GY-HD100 camera to capture the footage. Using the camera on Standard def it works fine. However when I try to capture footage in HDV, the computer tells me there is a communication error. Any info would be great.
    Andrew Hagan
    Paul Lewis replied 17 years, 2 months ago 3 Members · 2 Replies
  • Edgar Mills
    June 2, 2009 at 5:03 pm
    I have a similar post. Please lets keep each other informed on any new results
    thanks
  • Paul Lewis
    July 13, 2009 at 3:42 am
    The easiest way I have found it use a free utility called HDV Split.
    You can get it here
    https://strony.aster.pl/paviko/hdvsplit.htm
    Then import the file it creates from the camera.
    I use Avid Media Composer Adrenaline 2.8 with this and it works,
    plus you can convert the footage to Avid DNxHD codec.
    Hope that helps
    Cheers
    Paul Lewis
