Activity Forums Blackmagic Design JVC DT-V24L1D Monitor & Intensity Pro via HDMI/DVI-D
  • JVC DT-V24L1D Monitor & Intensity Pro via HDMI/DVI-D
    Posted by David Hames on September 17, 2008 at 4:03 pm
    Is anyone using the JVC DT-V24L1D 24″ HD display with Intensity? If so, is it possible to connect to this monitor using an HDMI to DVI-D cable? I didn’t know if there was some kind of issue since the monitor is 1920X1200. Also, if you’re using the Component connectors, are you pleased with the image quality?
    Thanks.
    David
    ____________________________________________
    RED Balloon Entertainment
    films and other visual enticements™
    http://www.balloonballoon.com
    Callum Mclay replied 17 years, 12 months ago 2 Members · 1 Reply
  • Callum Mclay
    September 19, 2008 at 9:12 pm
    Hi David
    The Intensity card only outputs YUV colour space over HDMI. DVI is a purely RGB colour space. Therefore, you will unfortunately not be able to use a HDMI to DVI adapter to connect to your screen, as your DVI monitor will not be able to display the video signal.
    Using the adapter to go the other way, from DVI to RGB works better, as HDMI can carry RGB or YUV. However, Intensity only ouptuts YUV as the more common video/television colour space.
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
