Activity › Forums › Apple Final Cut Pro Legacy › JVC capture to FCP
  • JVC capture to FCP
    Posted by Nicolas Clairmont on January 29, 2010 at 7:57 am
    Hi, Thank you in advance!
    I recently picked up a JVC-HD 100U and I’m trying to figure out the workflow… I’ve never used HDV before. the initial problem I ran into was that I captured to an external scratch and the footage doesn’t capture in real time… no big deal…
    But when i play it back once i’ve captured it, the clip plays back at double speed. The audio is normal, but anything I capture looks really slow as I’m capturing it, and than really fast once its finished.
    It’s not the tape I used b/c I tested another tape- same problem… Possibly the output settings on the JVC?
    The footage looks normal speed when i play it back in the camera viewfinder, It only looks wrong when I capture.
    Rafael Amador replied 16 years, 8 months ago 3 Members · 4 Replies
  • Rafael Amador
    January 29, 2010 at 2:47 pm
    Hi Nicolas,
    The footage only can be captured in real time: As gets in your system must be wrote down somewhere. if this doesn’t happens is because your HD is not up to the task.
    Are you using an USB HD, or a FAT-32 formated HD?
    rafael
    http://www.nagavideo.com
  • Phil Balsdon
    January 29, 2010 at 9:06 pm
    If you have FCP6 or FCP7 capture as ProRes. This eliminates a lot of problems people had with timecode breaks etc with this series of cameras. Whilst it creates larger file sizes it also gives a much better editing experience.
    Here’s how to do it. https://www.steadi-onfilms.com.au/vlog/?p=61
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
  • Nicolas Clairmont
    January 29, 2010 at 10:50 pm
    My hd is an “Iomega HDD” formatted for Mac OS “extended”… I only have one firewire port on my computer, so in order to capture, I daisy chain the camera through the 2nd firewire port on the HD.
    I found out right after i posted, that when i switched recording format to HDV-30p instead of 24p, That i no longer have the problem of capturing double speed. looks like i will be shooting 30p.
  • Rafael Amador
    January 30, 2010 at 2:16 am
    [Nicolas clairmont] “I found out right after i posted, that when i switched recording format to HDV-30p instead of 24p, That i no longer have the problem of capturing double speed”
    This makes me again that you have a problem with your HD.
    When you capture 24p, FC is discharging a 20% of the picture, so you are recording a lighter file.
    Download the AJA System Test utility and check the write/read speed on your HD.
    You may have a HD fast enough and with room enough, but if the directories are a mess, the HD may run very slow.
    rafael
