Activity › Forums › JVC Cameras › JVC BR-HD50 FCP6 capture problems
  • JVC BR-HD50 FCP6 capture problems
    Posted by Eric Lepage on March 18, 2009 at 8:07 pm
    Hello,
    I have some tapes that were shot on a JVC camera but the company I work for only uses Sony decks. I was finally able to locate a JVC BR-HD50 deck but I can’t seem to get my FCP6 to capture anything with it. I would ideally like to capture via firewire and I believe I have everything set correctly on the deck (IEEE 1394 set to HDV, remote menu and switch set accordingly, etc.) but I can’t seem to get FCP6 to recognize the device. I’ve tried some of the tips I’ve found in various forums but nothing seems to work so far. I can only hold onto this deck for a few days so I’m kind of starting to panic. Failing being able to digitize the footage I’d settle for a dub to my Sony HDV deck but I can’t seem to get a signal through the firewire. Any help would be very much appreciated.
    Eric
    Eric Lepage replied 17 years, 6 months ago 3 Members · 3 Replies
  • Johnny Clark
    March 18, 2009 at 9:10 pm
    Make sure you’re using an Intel Mac with FCP 6.0.5.
    If you’re using a G5 then go back to 6.0.1.
    Good luck.
  • Dave Farrants
    March 22, 2009 at 7:33 am
    I use a BR-HD50 with FCP 6.0.5 and a G5 (not Intel) with no problems. The deck had an FCP firmware update to 1.0.9.
    I did have a problem with a ‘fried’ FW output on the deck – nothing was coming out, this was fixed by JVC and a mod “firewire protection circuit’ was installed. This deck is the only bit of kit I’ve ever come across where it’s possible to insert the FW plug both ways in – ie: upside down, which then fries the socket.
  • Eric Lepage
    March 23, 2009 at 3:05 pm
    Thanks a lot. I got everything to work with that hardware and software combination. Much appreciated.
