Activity › Forums › JVC Cameras › JVC 250 Image is crooked?
  • JVC 250 Image is crooked?
    Posted by Chuck Pullen on April 4, 2011 at 2:05 pm
    Hello all, I am just starting to investigate a problem I have discovered with one of my JVC 250u’s. It seems that the image geometry is off, and in order to get a horizontally flat image you have to tilt the camera slightly to the right. I haven’t had time to investigate the problem further, but it seems that the issue is not the viewfinder, as the images shot with the camera “tilted” look fine when played back? I’m using the Fuji 17x lens btw…
    Chuck
    Marc Colemont replied 15 years, 5 months ago 2 Members · 1 Reply
  • Marc Colemont
    April 26, 2011 at 8:57 pm
    I think you best take the camera to a service center. As it sounds like your CCD block is loose inside?
    Are the images still sharp and crisp?
