Activity › Forums › Adobe Premiere Pro › justify title in Premiere 1.5
  • justify title in Premiere 1.5
    Posted by Enginn Heima on February 18, 2006 at 12:23 pm
    I can’t see a way to “justify” titles in the title tool that comes with premiere. NB I’m trying to “justify” not align it right, left or center which are the three options.
    Any help apreciated,
    regards,
    moldvarpan
    Enginn Heima replied 20 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Steven L. gotz
    February 18, 2006 at 9:22 pm
    You might have to do it manually. Each line can be kerned separately, as can each space between words. Neither Premiere Pro or After Effects was designed to justify text.
    Steven
    http://www.stevengotz.com
  • Enginn Heima
    February 19, 2006 at 7:57 pm
    Thank you Steven.
    But how do I kern each space between words? Is there a way to format a whole paragraph, or do I really have to go on each space and kern? Sorry, I’m a bit lost in this thing…
    Regards,
    moldvarpan
  • Steven L. gotz
    February 19, 2006 at 8:16 pm
    Select each space is the only way I know of. Unless you are so close to hitting both edges that you can select the entire line and kern everything on the line to fit. But it will not be easy.
    Why in the world do you need to justify text?
    Perhaps you should be using Photoshop to create the text. Photoshop can justify text once it is converted to paragraph text instead of point text. But be careful when doing so. You may need to soften the edges, and perhaps have a soft shadow. Avoid pure black or pure white.
    Steven
  • Enginn Heima
    February 19, 2006 at 10:10 pm
    Thanks Steven.
    I’m subtitling, and I simply like “justified” subtitles.
    Any good tips on subtitling plugins or some tips on subtitling with Premiere….
    Best regards,
    moldvarpan
  • Steven L. gotz
    February 19, 2006 at 11:04 pm
    If I were subtitling, I would do it in After Effects because you can animate the text parameter. Not just the look of the text, but the actual words. So you keyframe when each new sentence shows up. Pretty simple.
    Steven
  • Craig Howard
    February 20, 2006 at 12:15 am
    Select the shortest line and kern that to the longest line length. Can look a bit strange if the line lengths are too disparate but otherwise works well.
    Looks real nice for big graphics also.
  • Enginn Heima
    February 21, 2006 at 9:00 am
    Thanks guys.
    Regards,
    moldvarpan
