Activity Forums Apple Final Cut Pro Legacy just upgraded to Tiger now Compressor won’t open
  • just upgraded to Tiger now Compressor won’t open
    Posted by Keely72 on November 12, 2006 at 6:02 pm
    I just upgraded to Tiger and now Compressor won’t open. I have Final Cut Pro HD and Compressor 1.2.1. My Export>Using Compressor option is grayed out and when I try to open Compressor on it’s own it won’t. Any ideas?
    Thanks in advance.
    Keely
    Walter Biscardi replied 19 years, 10 months ago 3 Members · 2 Replies
  • Zak Mussig
    November 13, 2006 at 3:40 pm
    Keely,
    That sounds like par for the course. I would re-install all of your pro apps. An OS update is a big deal on a system that really needs to be stable. Update your OS to 10.4.8 then install FCS (or FCP and friends) again. Then update that as high as it will go. You have to have the universal version to get the latest updates (and they’re very worth it).
    Zak
  • Walter Biscardi
    November 13, 2006 at 3:45 pm
    [Zak Mussig] “An OS update is a big deal on a system that really needs to be stable. Update your OS to 10.4.8 then install FCS (or FCP and friends) again.”
    In fact to really get a stable system, you should really Erase and start over from scratch when doing a major OS change, such as from Panther to Tiger. This is what I did and it creates a completely stable system.
    Back up all the items you need to save off the main system drive. Then insert the Tiger CD, then choose “Erase and Install” from the options. This erases your hard drive and installs a clean OS on your system. Then run Software Update to update everything in your OS. Then start installing all of your software again, running Software Update for any Apple software immediately after installing it.
    This usually takes me two days to fully complete and test everything but it’s definitely worth it.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
