Activity › Forums › Blackmagic Design › Just upgraded to FCP 5.1 – no video playback
  • Just upgraded to FCP 5.1 – no video playback
    Posted by David Eells on June 23, 2006 at 6:16 pm
    Show Current Frame works (just shows a still)
    Show All Frames does not
    Video Black goes to output monitor
    OSX 10.4.6
    FCP 5.1
    BM driver 5.6
    QT 7.1
    Using BM NTSC 8-bit easy setup
    If I boot into 10.3.8 off of my other HD and run FCP 4.5, everything’s fine.
    I haven’t been able to find this particular problem
    David Eells replied 20 years, 3 months ago 2 Members · 5 Replies
  • David Eells
    June 25, 2006 at 2:50 pm
    NT
  • Kristian Lam
    June 27, 2006 at 8:05 am
    Please try removing existing drivers using the “Uninstall Blackmagic” application, then re-install the drivers again.
    regards
    Kristian Lam
    Blackmagic Design
  • David Eells
    June 27, 2006 at 1:43 pm
    Here’s what I did:
    Upgrade to Tiger
    Upgrade to FCP 5.1
    Download BM 5.6 driver
    Uninstall Bm drivers
    Install new BM driver
    Unable to get video output
    Booted to previous version – worked as expected
    Contact BM
    Post on Cow
    Uninstall BM driver as advised
    Reinstall BM driver as advised
    No joy
    Upgrade to FCP 5.1.1
    Unistall BM driver
    Reinstall BM driver
    No joy
  • Kristian Lam
    June 28, 2006 at 8:16 am
    Ok, what kind of “upgrade’ to Tiger did you do?
    Have you done a clean install of Tiger instead of an upgrade install?
    regards
    Kristian Lam
    Blackmagic Design
  • David Eells
    June 28, 2006 at 3:25 pm
    Hi Kristian
    I guess a clean install is the next step. I’ll get back to you in a couple of weeks.
