Activity Forums Apple Final Cut Pro Legacy Just to double check: there is no way to change color in Boris Text 3-D without going through each clip individually and I cannot paste attributes. correct?
  • Just to double check: there is no way to change color in Boris Text 3-D without going through each clip individually and I cannot paste attributes. correct?
    Posted by Noam Osband on June 1, 2012 at 12:05 am
    I have a lot of boris 3-D text subtitles and i want to change all their colors from yellow to white. I cannot paste attribute and do this. i need to change each one individually. correct?
    noam
    Shane Ross replied 14 years, 3 months ago 2 Members · 1 Reply
  • Shane Ross
    June 1, 2012 at 12:59 am
    Yup…gotta be done manually. As Boris titles are a separate interface that you open. THe attributes are invisible to FCP.
    Stinks, but…
    Shane
    Little Frog Post
