Activity › Forums › Adobe Premiere Pro › Just Switched from FCP – Workflow Hiccups
Ally Shore replied 13 years, 4 months ago 6 Members · 13 Replies
Garrett Hestla
May 25, 2012 at 8:27 pmI’m having the same problem with CS6 and dissolves. I can drag them from the panel and they work fine. I cannot get the shortcut keys to work at all, FCP7 or Default.
Cade Muhlig
March 24, 2013 at 1:58 amdouble click on the edit between the two clips to move your playhead marker there, then keyboard shortcut cmd-d
Ally Shore
April 28, 2013 at 3:21 amHi Gates,
I”m having the exact issue you did. For some reason in the default settings the command-d works, but nothing you set it to in the custom settings will get the default transition to work. (ie: command-t) Did you ever find an answer?thanks
Ally
