Activity › Forums › Apple Final Cut Pro Legacy › Just read in library that we should not Journal our HDD.
Posted by Delano Bryant on November 12, 2007 at 9:47 pmBUT, my RAID is extended (Journaled). Which should it be?
Is that the color red you want to use?
Jeremy Garchow replied 18 years, 10 months ago 8 Members · 15 Replies -
Don Greening
November 12, 2007 at 9:58 pmTurn journaling off for any media drives. Journaling will, with varying degrees, interfere with the capture and editing process.
– Don
Delano Bryant
November 12, 2007 at 10:01 pmHow do I turn off Journaled on the RIAD drives?
Walter Biscardi
November 12, 2007 at 10:02 pm[Hdfilmmaker] “BUT, my RAID is extended (Journaled). Which should it be?”
Media arrays should NEVER be journaled. This has been repeated on this very forum dozens if not hundreds of times over the years.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Delano Bryant
November 12, 2007 at 10:03 pmWhen I raided them, they automatically journaled? How do I undo?
Don Greening
November 12, 2007 at 10:11 pm[Hdfilmmaker] “How do I undo? “
Just go through the same process again but choose “journaling off” this time. You won’t hurt anything by reformatting.
– Don
Jeremy Garchow
November 12, 2007 at 11:29 pmSorry guys, I have to play devil’s advocate here. Sonnet recommends journaling the D800RAID. Why? It helps to have a journal when reconstructing the RAID.
Huge Systems also recommended it:
https://forums.creativecow.net/archivepost/146/714905
https://forums.creativecow.net/archivethread/146/570712#570712
https://forums.creativecow.net/archivepost/146/590657
What kind of RAID do you have, HDFIlmmaker?
Also, I prefer PANTONE 179
Jeremy
David Roth weiss
November 12, 2007 at 11:29 pm[Don Greening] “You won’t hurt anything by reformatting.”
Just to be absolutely clear, Don did not mean to imply that reformatting would not erase all files from your raid array, because it will…
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Baz Leffler
November 12, 2007 at 11:51 pm[David Roth Weiss] “Just to be absolutely clear, Don did not mean to imply that reformatting would not erase all files from your raid array, because it will…”
DAMN! too late :>(
Keyframe
November 13, 2007 at 1:32 amYou may wish to review the following article:
https://docs.info.apple.com/article.html?artnum=107249
In particular, look at the end of the article for instructions about disabling journaling.
However, I do believe Jeremy provides enough support for an alternative view to what Walter seems to state as undisputed fact. Of course, maybe Walter and others have done sufficient testing to support their contention that “Media arrays should NEVER be journaled.” It is possible that they have generated test results to counter the tests and recommendations made by the FCP engineers as mentioned in the (old) 2004 post.
Steve Grimes
Don Greening
November 13, 2007 at 1:45 am[David Roth Weiss] “Just to be absolutely clear, Don did not mean to imply that reformatting would not erase all files from your raid array, because it will…”
You’re quite right, David. I should have been more specific. Never assume that because someone is formatting a RAID that there’s no media on it.
– Don
