Hi there…glad you’re using InDesign. As a PageMaker user, you’ll want to make sure you have your “PageMake toolbar” turned on to help you transition…I think they added that in CS3, but might have been CS2…can’t remember. Anyway, yes, there is a pasteboard for each page, essentially. But for using items you need quick, and possibly multiple, access to, I’d suggest using a library. When you create a library (File–>New–>Library), it’s document independent and floats in its own palette/panel. If there’s an item you want to use from your page, simply drag it into the Library. Next time you want to place that on a page, grab it from the library and drop it onto the page. You can put all items on a page as a group in a library, or each item individually. You can even put things like sets of guides in a library…but you can’t drag and drop, you’ll need to use the Libary Panel menu (It will give you a warning and instructions if you try to drag and drop guides). You can even assign keywords and do a search feature to library items. Check out libraries…much better than having a bunch of junk lying all around your page!
Erica Gamet
Digital Dimensions
https://www.digi-wizard.com/learn
“…for there is nothing either good or bad, but thinking makes it so.”
