Activity Forums Adobe After Effects Just need some simple help
  • Just need some simple help
    Posted by Austin Flynn on June 13, 2008 at 4:09 pm
    Hey guys i am new to after effects and i know the basics of how to use it and i have one simple question. It seems that when i add an effect(s) there is always two green lines that form an X across my screen and i was wondering how i could turn them off. Much thanks to anyone who responds!
    Frank Thomas replied 18 years, 3 months ago 3 Members · 4 Replies
  • Darby Edelen
    June 13, 2008 at 5:47 pm
    [Austin Flynn] “It seems that when i add an effect(s) there is always two green lines that form an X across my screen and i was wondering how i could turn them off.”
    That usually means you’re using a plug-in that is not registered (a trial version).
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Austin Flynn
    June 14, 2008 at 1:33 pm
    ya i had the trial but then i bought it online and when i go to the help tab and then go down to registration it says i need an active internet connection and java running which i do so can i get around it or do i just need to keep trying to register
  • Darby Edelen
    June 16, 2008 at 8:26 pm
    [Austin Flynn] “so can i get around it or do i just need to keep trying to register “
    I would recommend contacting the support department for the plug-in distributor/producer.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Frank Thomas
    June 17, 2008 at 2:01 am
    Try using two instances of simple wire removal, one for each diagonal line. You may need to apply one instance, pre-compose, then apply the second instance.
