Activity Forums AJA Video Systems Just a small resolution humbug with P2 !!
  • Just a small resolution humbug with P2 !!
    Posted by Richard Chin on January 10, 2007 at 4:10 pm
    I know there is probably a simple reason for this one but I could find nothing in the archives.
    Take a look at this scenario.
    I have some P2 footage shot at 1080i from the HVX200 on my LHe system.
    My external monitor displays the 1920 x 1080 image and the 2nd monitor shows the downconveted SD image .
    However item properties on that clip states that it is 1280 x 1080. So which is it? 1920 x 1080 or 1280 x 1080.
    Secondly if I export this clip for compositing on a PC (as animation codec) which resolution should I use?.
    Any thoughts?!
    Richard
    Richard Chin replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mark Maness
    January 10, 2007 at 5:20 pm
    [Richard] “However item properties on that clip states that it is 1280 x 1080. So which is it? 1920 x 1080 or 1280 x 1080.”
    That’s because Panasonic’s DVCProHD codec is 1280×1080, just like Sony’s HDV codec using 1440×1080. AJA cards interpolate the footage to its full sized resolution. The ONLY way to get 1920×1080 from a Panasonic camera is to capture the footage live using an Uncompressed codec, not even using the P2 cards in the camera.
    There’s nothing wrong with the resolution at 1280×1080. As a matter of fact, you’d be hard pressed to tell if the footage is 1920×1080 Uncompressed or 1280×1080 DVCProHD.
    [Richard] “Secondly if I export this clip for compositing on a PC (as animation codec) which resolution should I use?.”
    ALWAYS export using the codec you are editing. The footage will not get any better exporting to Uncompressed.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Richard Chin
    January 10, 2007 at 7:58 pm
    Ok thank you, I knew there was a simple enough reason for this.
    On the export to PC, I must use another codec other than DVCPRO HD because of the whole licensing thing that prevents PC’s from reading mac DVCPRO HD Files. It was explained in more detail in a previous post in here somewhere.
    Thanks again
    Richard
