Activity Forums Apple Final Cut Pro Legacy Just a quickie – using decklink codec without decklink card
  • Just a quickie – using decklink codec without decklink card
    Posted by David Dubois on September 7, 2007 at 2:35 pm
    Hi all,
    I’m about to do an online from Digibeta at a facility.
    I need to take the online footage and transfer it onto my laptop in order to do the colouring & sound mixing at home.
    The facility will be onlining through sdi on the decklink card (not sure which one) and I’m just making 100% sure that I’ll be able to play the footage if I download and install the decklink codecs on my system?
    Also, is digibeta 8bit or 10bit for the uncompressed files?
    Thanks in advance.
    Dave
    PS I’ll be playing back off a FW800 drive, will 8bit/10bit uncompressed (1 stream) play back ok? If not, it’s not the end of the world as I can do export as movies to check the film I guess.
    Currently working on ‘Lookin’ For Lucky’ – Feature Film for Albino Injun Productions.
    http://www.lookinforlucky.co.uk
    Chris Borjis replied 19 years ago 2 Members · 1 Reply
  • Chris Borjis
    September 7, 2007 at 3:05 pm
    1 stream should be fine.
    I always work in 10-bit regardless, but 8-bit would also work.
