Activity Forums Adobe InDesign Just a neat tip
  • Just a neat tip
    Posted by Kelly Johnson on May 8, 2005 at 9:22 pm
    When in Quark, after styling type select the type and under Edit choose to Save Text As and choose Rich Text Format.
    You can then import (place) the type into a type frame in InDesign CS and all the styling will remain.
    Fast work arounds if type is needed in a Quark 6 document and there’s no version 5 around/
    Kelly Johnson replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
